tbrand Posted June 5, 2011 Share Posted June 5, 2011 So, I'll be throwing a set of WJ control arms on my truck - uppers and lowers. When I'm lifting it, where's the best place for the jackstands? Should they be somewhere on a "frame rail" or would they be better on the axle? Also, I was planning on just pulling/replacing one arm at a time - is there a better way? I'll be using this thread as a guide. http://comancheclub.com/forums/viewtopic.php?f=9&t=20533&hilit=control+arm Link to comment Share on other sites More sharing options...
mj Mike Posted June 5, 2011 Share Posted June 5, 2011 When I'm lifting it, where's the best place for the jackstands? Should they be somewhere on a "frame rail" or would they be better on the axle? Yes Keep your jack stands under the the Frame rails, between the LCA mount & the trans cross member. Do not place them further back then the trans cross member! My long arm brackets force my jack stands Back to the cross member, but you can see that you can put them much further forward towards the stock LCA mounts , this macks the truck much more sturdy Link to comment Share on other sites More sharing options...
dakal Posted June 5, 2011 Share Posted June 5, 2011 also, only do one at a time. Link to comment Share on other sites More sharing options...
dakal Posted June 5, 2011 Share Posted June 5, 2011 :hijack: mike are you running coilovers? what kind? same for bumpstops. Link to comment Share on other sites More sharing options...
tbrand Posted June 5, 2011 Author Share Posted June 5, 2011 So, once I've got it lifted up and on the stands, the front axle will just be hanging, yes? Link to comment Share on other sites More sharing options...
mj Mike Posted June 5, 2011 Share Posted June 5, 2011 Ideally you don't want the axle to be at full droop. You just want to support the axle a little, without compressing the coils. Its not coil over's, they are Fox 2.5 by 10inch Bypass Shocks, and Fox Bumps with Deaver Coils. If you are interested, check out page 4 of my build thread, link is at the bottom of post. Link to comment Share on other sites More sharing options...
