Do I need a new fuel pump?
My 88 Comanche 2.5l is getting harder to start. It cranks for more than 5 seconds before it starts. The fuel pressure at the throtle body is 15 psi with the engine running. As soon as I shut it down, it drops to 0. Is it possible that there is a check valve in the fuel pump that is not working? Should the system hold pressure when the engine is off? It seems to be running fine when it is running.
