vhenem Posted May 15, 2011 Share Posted May 15, 2011 A long shot i know bit I am in need of a sending unit/fuel pump for a HO MJ, either 91 or 92 Its a LWB, 16Gal. Tank if that makes any difference. Link to comment Share on other sites More sharing options...
Jeepman Posted May 16, 2011 Share Posted May 16, 2011 Go to your local Fuel tank/Rad shop and they should be able to rebuild yours or make you a new one as They are not available anymore if they can not do it then look up on the internet as there are companies that you can send your sender to and they will rebuild and make you one to match... I had to make a new one a few years ago for my MJ and if you can do the work your self then you need to purchase a new Cherokee Sender for the same year as your MJ and then cut, twist and extend it and you will have a new one which is exactly what I did... Good luck... Link to comment Share on other sites More sharing options...
