madwild Posted May 13, 2011 Posted May 13, 2011 Heard about a TSB on installing a ballast resistor like the ones on mid 87+ but i cannot find it, does anyone know how to fix this or has dealt with this? The fuel pump can be heard inside. I also heard about installing a 4runner fuel pump. Any input would help. thanks. Mine is the silver MJ http://www.jeepforum.com/forum/f11/not- ... ndex5.html
maddzz1 Posted May 13, 2011 Posted May 13, 2011 I don't think the wiring to add the ballist resistor is there. Without changing to a later wiring harness I don't know how you would add one, unless it could just be spliced into the correct wire.
madwild Posted May 13, 2011 Author Posted May 13, 2011 I don't think the wiring to add the ballist resistor is there. Without changing to a later wiring harness I don't know how you would add one, unless it could just be spliced into the correct wire. U are right, I didn't think about changing the wirering system. frome early renix to 88-90 renix. that would be alot of work though.
