flint54 Posted April 22, 2011 Share Posted April 22, 2011 The 1997 and up 10 blade electric cooling fan is supposed to move more air (don't remember the numbers), and my question is, does anyone know if the motors are the same and can one simply change the fan blade, or is there a change in motor also? I know the assembly is simple direct swap but are the blades also? Thanks! Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 23, 2011 Share Posted April 23, 2011 The 1997 and up 10 blade electric cooling fan is supposed to move more air (don't remember the numbers), and my question is, does anyone know if the motors are the same and can one simply change the fan blade, or is there a change in motor also? I know the assembly is simple direct swap but are the blades also? Thanks! The motors will swap between fans. But you can't take an 8 or 10 fan blade and motor assembly and swap it into the old 5 blade housing as the fan blade will hit on the housing. It's built differently. Link to comment Share on other sites More sharing options...
Sir Sam Posted April 23, 2011 Share Posted April 23, 2011 The 96 fan is the same as the 97+ but will have the correct connector for an MJ. Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 23, 2011 Share Posted April 23, 2011 Hmmm. Most of the 96 fans I've seen were 8-bladers. But 96 was a FU year. Link to comment Share on other sites More sharing options...
