mdwatson Posted April 22, 2011 Share Posted April 22, 2011 Need help. I have a 87 MJ with 4.0 and auto transmission that I bought a couple months ago. The trans shifted fine with no problems untill I replaced the rear main seal on the motor. Finished up the seal early sunday and drove the truck around the rest of the day as usual with no problems. Went to go to work the next morning and the trans wouldn't shift out of second and had to use my other truck. Got home that evening and test drove it and it shifted fine. The next morning same problem and wouldn't shift. So far I have changed the fluid and filter (fluid was dark brown) and replaced a section of line that was mashed flat and I also looked to see if I accidently damaged any elect lines when I pulled the oilpan and found nothing. I don't know what else to do. The truck was unhooked from the battery for about two days when I replaced the seal so do you think it could have caused any computer problems? Link to comment Share on other sites More sharing options...
Garry '89/4.0 Posted April 22, 2011 Share Posted April 22, 2011 Oye Mate, don't panic! I just went through the same same with my new to me '89. Hopefully this will take you to the relevant post: viewtopic.php?f=2&t=29434&p=297472&hilit=aw4+won%27t+shift#p297472 (if that doesn't work search for "AW4 won't shift") In the meantime to check that its not the tranny pull your TCU (trans computer) fuse. It's behind the lower trim panel under the glove box area on a harness. You shouldn't have to remove the panel/TCU, just the fuse. You should then be able to use the trans manually (start in 1-2 up to 3rd etc.) Be real careful when stopping and backing up. Bring everything to a complete stop before shifting. If you would like the AW4 manual and trouble shooting guide pm me. Also, lots of help available here. best, |Garry| Link to comment Share on other sites More sharing options...
mdwatson Posted April 22, 2011 Author Share Posted April 22, 2011 Thanks Garry that will help me out a lot!!! Link to comment Share on other sites More sharing options...
