MancheKid86 Posted April 16, 2011 Share Posted April 16, 2011 any replacement weld in patches for the well from the box to the side of the sheet metal? or do i have to get some custom made? Link to comment Share on other sites More sharing options...
Boots Posted April 17, 2011 Share Posted April 17, 2011 Have you looked at XJ's mabe there close enough to work? :wrench: Link to comment Share on other sites More sharing options...
flint54 Posted April 17, 2011 Share Posted April 17, 2011 I'm too "forum" ignorant to know how to attach previous threads, but if you're able to look up past posts from/by me you might see some info. I believe the only way this problem can be solved is by salvaging a couple good parts from another truck, then drilling out the spot welds on that item as well as yours, and then welding it into your truck While that piece is out I suggest a good coat in the inner surfaces (POR-15 is great) to slow down future corrosion. It was a slow job, but not all that difficult. I bought a good piece from a forum member who sawed out what I needed. (item #7 or #8 in diagram depending on side). I am 99.999% certain that the part you need is not available new. Rust really sucks. Image Not Found Link to comment Share on other sites More sharing options...
