Tranny question
i was under my jeep today about to bleed the clutch.. (it has been leaking at the master cylinder and i finally ordered the replacement part) and i could wiggle the bleeder tube a good bit. should that wiggle at all?
Also while i was under there i needed to check my tranny fluid... (oil was leaking a good bit and not from the engine... and it finally stopped leaking) it had been getting hard to shift into gear.
could some one tell me if the big nut in the center is the refill or is it the hole above it which was missing a nut... :hmm:
5617746192_1dba2551d9.jpg[/img]
Thanks
