Multi-function switch
Hey, guys, I'm finally getting back to working on my Comanche, and the multi-function switch is acting up, if you wiggle it the wipers stop working and the high-beams don't work, so I'm thinking the switch is bad, I figure one from an 86-90 will work, I was wondering if a new one would work as well say 91-96 or newer, and do I have to get another one from a tilt column?
If it matters its an 88 4.0 B/A-5 with intermittent wiper switch currently and tilt steering wheel.
TIA
If it matters its an 88 4.0 B/A-5 with intermittent wiper switch currently and tilt steering wheel. TIA
All the above matters: tilt/non-tilt, delay wipers or not, column/floor shift, and vehicle year. Here's a good place to find the right one:
http://www.jeep4x4center.com/jeep-turn-signal-components/jeep-cherokee-xj.htm
