NLargen90 Posted March 28, 2011 Share Posted March 28, 2011 Hi guys I'm new to the forum. I just got a 1989 jeep comanche I was taking her through a mud hole and in the process I think i messed something up. All of my lights in the front work. I have only one rear turn signal working (on the drivers side) back up lights are working, but I have no rear parking lights. I have checked all the fuses they look good bulbs are good. So I'm assuming its a wiring problem. Has anyone had this problem that could help me out? I can post pictures of my wiring if needed. Thanks Link to comment Share on other sites More sharing options...
jimoshel Posted March 28, 2011 Share Posted March 28, 2011 It's a toss up between bad ground or trailer wiring. Remove the left rear tail light. There's a self tapping screw grounding a wire, can't remember if it's one or two wires. Make sure it's clean. Look underneath for signs there was a trailer wiring hooked up. If so, remove all traces of the old wiring and inspect what's left for open or grounds. I like a product called liquid electrical tape, for covering worn insulation. Take a test light and check at the sockets for voltage. Also look for corrosion around the sockets. If they're really bad, replace them. Link to comment Share on other sites More sharing options...
NLargen90 Posted March 29, 2011 Author Share Posted March 29, 2011 thanks ill check that now. I had trailer lights I removed every trace of them. I'm going to check the ground next. Link to comment Share on other sites More sharing options...
NLargen90 Posted March 29, 2011 Author Share Posted March 29, 2011 It's a toss up between bad ground or trailer wiring.Remove the left rear tail light. There's a self tapping screw grounding a wire, can't remember if it's one or two wires. Make sure it's clean. Look underneath for signs there was a trailer wiring hooked up. If so, remove all traces of the old wiring and inspect what's left for open or grounds. I like a product called liquid electrical tape, for covering worn insulation. Take a test light and check at the sockets for voltage. Also look for corrosion around the sockets. If they're really bad, replace them. So I checked the ground and it was causing all of my lights to go out. I now have taillights and the rest but I still only have a drivers side turn signal in the rear. Could this be one of the bigger metal fuses under the dash or would it still be some wiring I missed from the trailer lights? Thanks again it is at least drivable now at night. Link to comment Share on other sites More sharing options...
jimoshel Posted March 29, 2011 Share Posted March 29, 2011 How about stop light? On both sides? If just the driver side signal light is the only one working it could be one of two causes. A faulty wiring or socket or the signal switch. Don't overlook the most obvious , bad bulb. Link to comment Share on other sites More sharing options...
NLargen90 Posted March 29, 2011 Author Share Posted March 29, 2011 How about stop light? On both sides? If just the driver side signal light is the only one working it could be one of two causes. A faulty wiring or socket or the signal switch. Don't overlook the most obvious , bad bulb. I'll check the stop light. I didnt think about that actually. I put new bulbs in both sides. All of the lights light up just when i hit the turn signal it doesnt flash The front does just not the rear. Link to comment Share on other sites More sharing options...
NLargen90 Posted March 29, 2011 Author Share Posted March 29, 2011 Stop light works fine. I'll check the bulb after pt this morning then the wiring and if all else fails the switch. Link to comment Share on other sites More sharing options...
NLargen90 Posted April 11, 2011 Author Share Posted April 11, 2011 Finally figured it out. I have a slow leak in my master cylinder it was leaking onto the wire for the tail lights that goes into the fuse box and causing it to not get a connection. Link to comment Share on other sites More sharing options...
