any one have a chart with the bearing numbers?
i need to get a re-placement since one of them went,
got a bearing press, can do all the work at home, just need the number (have a harbor freight parts book :roll: :yes: will order from there)
Which bearing is toast?
P/S? In the pump (replace pump)
Water pump? In the pump (replace pump)
Idler pulley? $15 (replace pulley)
Alternator, A/C ??
