wrangler trans swap
As long as both are 4.0l's it should work. Only issue is the transfer case is clocked a little different but guys have still made it work.
you should add more info when you ask a question it will help people answer,I would bet that your 89 comanche is setup quite different compared to my 89 comanche.
