A/C REMOVAL
Has anyone ever removed the A/C condenser and re-routed the belt? My A/C is done, and I disconnected (via Sawzall) the refrigerant lines and electrical, leaving the non-op condenser. I would like to eliminate the hollow condenser all together, but don't know if a different pulley needs to be installed in it's place or the belt re-routed. Any ideas?
It's a '92 4WD 242ci with a 5-speed....
Its a compressor and you don't have to buy the pulley to take its place because you have the compressor doing that. When its not engaged its literally just a pulley. If for some reason you don't like looking at the compressor then you can get a Dorman dummy pulley ac eliminator pulley and bracket.
