Short answer, yes.
Both windshields are the same.
Only difference isn't really a "seal" but a "trim" metal vs rubber.
To use the rubber one you might have issues with the "nubs" that held the chrome in place, some say you have to remove them
others say you don't. When you put the glass in, for the rubber one you put it in with the glass (both use the same urethane
sealer) when using the chrome, it goes on after the glass is installed.
