neverstuck Posted February 22, 2011 Share Posted February 22, 2011 Need D35 with 3:55s for a comanche. Drum to drum preferably but whatever. I heated up my right rear bearing and the axle came on out last night. Atleast i was doin ten mph. I'm in NJ so the closer the better Link to comment Share on other sites More sharing options...
pamike Posted February 22, 2011 Share Posted February 22, 2011 can't you just replace the bearing and/or axle shaft? or is damage done to the housing? i have one with 3.54 gears but the pinion bearing and seal are bad. axle shafts and everything else is good. Link to comment Share on other sites More sharing options...
btm24 Posted February 24, 2011 Share Posted February 24, 2011 I have one I just took out of my truck not to long ago. Every thing works on it but I'm in FL :( Brandon Link to comment Share on other sites More sharing options...
