Dave Stark Posted February 20, 2011 Share Posted February 20, 2011 '91 Comanche 4.0 156k miles AX15 I can't get it to run, it will hit, miss, & die. It has been sitting for a couple months, but i have done nothing under the hood & it ran fine before i parked it. It has a fresh battery & has been indoors the entire time. :wrench: Link to comment Share on other sites More sharing options...
jimoshel Posted February 20, 2011 Share Posted February 20, 2011 Get a gauge and check your fuel pressure. If you don't have one dribble some gas into the TBI. I use a sprayer for that. T his will help determine if it is a fuel or ignition problem. Gas shouldn't have went bad in a couple months time to be causing the problem. Possible but not likely. Link to comment Share on other sites More sharing options...
Dave Stark Posted February 21, 2011 Author Share Posted February 21, 2011 Get a gauge and check your fuel pressure. If you don't have one dribble some gas into the TBI. I use a sprayer for that. T his will help determine if it is a fuel or ignition problem. Gas shouldn't have went bad in a couple months time to be causing the problem. Possible but not likely. Jim, I believe you are correct, i siphoned the seven gallons remaining in the tank & oh boy was it nasty. I tried running some 93 through it, but that was only enough to get her back in the garage, so now i have the overwhelming joy of cleaning my fuel system... ~Dave Link to comment Share on other sites More sharing options...
