More Brakes - Dual Piston Caliper Mod?
Now that I'm nearing done on the rear disc brake conversion, I'm headed up
front next. Since I'm going to be changing out axles anyways (3.07 to 3.55)
I see an opportunity to upgrade the brakes. I've read the other forum posts on
using the TJ hubs and WJ knuckles/calipers. It seems do-able, but all write-ups
caution that the calipers will not clear 15" wheels without shaving. I'm not going
to change wheels, I just had mine refinished and like them too much. My questions are:
1) concerns about shaving calipers (assuming they don't leak)?
and
2) have any of you done this mod on your MJ?
Thanks!
caution that the calipers will not clear 15" wheels without shaving. I'm not going to change wheels, I just had mine refinished and like them too much. My questions are:
and
2) have any of you done this mod on your MJ? Thanks!
While I haven't done it, I've been looking at this mod closely and share your concerns. I would definitely not shave the calipers, but would consider using just enough spacer I'd need to clear the caliper. But I don't like doing that either. I managed to find a substitute two-pot caliper with similar mounting specs to replace the old single pot caliper on my bike, but no luck yet for the MJ. :(
Also, some 15" Jeep wheels have a larger inside circumference than others. For instance when I installed rear disks, the Ravine wheels had enough ID to clear the caliper, but when I swapped to the turbine wheels I had to use spacers. The Canyon wheels wouldn't work either.
Yes, the Vanco is a great option, except they charge $750, plus $200 core charge.
Plus, the knuckles I would send them they would probably reject due to rust.
I figure I can score nearly all the necessary hardware at the JY for around $250 or
so.
