comanche12 Posted February 14, 2011 Share Posted February 14, 2011 hey guys i just did two man bleed method, when i pumped the brake pedal the pedal keep feel slippary. even when take turn to other guy(my brother), he said same thing that pedal feel slippary easy. Sp we want to get it grip like my impreza which won't slip off when depress the pedal. so do you guys have any aftermarket pedal rubber pad to prevent slip off? same with clutch pedal tho Link to comment Share on other sites More sharing options...
Automan2164 Posted February 14, 2011 Share Posted February 14, 2011 Why don't you just take the rubber off and put on some skateboard grip tape? But I really don't think the pedal covers are "slippery"... Are you sure you didn't get any oil behind them? Tried some double sided tape to keep the rubber from sliding around? Rob L. :dunno: Link to comment Share on other sites More sharing options...
comanche12 Posted February 14, 2011 Author Share Posted February 14, 2011 Why don't you just take the rubber off and put on some skateboard grip tape? But I really don't think the pedal covers are "slippery"... Are you sure you didn't get any oil behind them? Tried some double sided tape to keep the rubber from sliding around? Rob L. :dunno: they does the rubber pad is worn out, there little groove on them. I'm talking about my feet keep slippary out of pedal even it hard to stay on while *pump* depress it for bleeding the brakes. for example when i depress the pedal then i start feel my foot(shoe) start slip off from brake pad. won't stay on. like there mud cover on pedal. edit: its pretty good idea to use skateboard grip, ill try it later when start my new job next week Link to comment Share on other sites More sharing options...
MJRemi Posted February 14, 2011 Share Posted February 14, 2011 New pads at Team Cherokee=$3.25 http://www.teamcherokee.com/Brakes/index.html Link to comment Share on other sites More sharing options...
comanche12 Posted February 14, 2011 Author Share Posted February 14, 2011 thats would be better! thank you! :cheers: Link to comment Share on other sites More sharing options...
