acfortier Posted February 14, 2011 Share Posted February 14, 2011 Order a new gas tank and straps from Rock Auto. Now, do I need to get anything else? The tank comes with the lock ring and o-ring for the fuel sending unit, and as for the filler neck that is just a simple unclamp from the old and clamp on to the new right? Link to comment Share on other sites More sharing options...
jimoshel Posted February 14, 2011 Share Posted February 14, 2011 Take a look at the old. If it's cracked, dry, brittle then replace it. If there's no cracks and it's flexible then it's OK to reuse. Link to comment Share on other sites More sharing options...
acfortier Posted February 19, 2011 Author Share Posted February 19, 2011 What are the two holes on the top of the tank? Are they just breathers? Do I have to get replacements for those too? Also, the straps I ordered didn't come with bolts. Just make a run to the hardware store to find one that matches? Link to comment Share on other sites More sharing options...
flint54 Posted February 19, 2011 Share Posted February 19, 2011 The two holes on top of the tank are vent lines, but they have a rollover valve installed that prevents loss of fuel when you're upside down. The grommets that hold those valves deteriorate with age. If you're really careful, and have lived an honorable life, you just might be able to salvage your old ones but don't count on it. They are still available from the dealer, they cost about $10 each, and will likely have to be ordered. If you're not certain the old ones are good, I suggest just replacing them. It sure beats pulling the tank again! Link to comment Share on other sites More sharing options...
flint54 Posted February 19, 2011 Share Posted February 19, 2011 The strap bolts are unique. They're a J-bolt that hooks into the frame. If you old ones had to be cut you'll need new ones, and they're NLA at dealer. I was very lucky and found a good pair at the JY. Hope yours are still good. Link to comment Share on other sites More sharing options...
acfortier Posted February 19, 2011 Author Share Posted February 19, 2011 Ah ok thank you for the reply! That helps alot, but damn I wish I knew about that earlier... Now I will probably have to wait longer for those parts... Link to comment Share on other sites More sharing options...
acfortier Posted February 20, 2011 Author Share Posted February 20, 2011 Has anyone else had any luck finding the strap bolts for the gas tank? Link to comment Share on other sites More sharing options...
