comanche12 Posted January 23, 2011 Share Posted January 23, 2011 I start noticed that there a lot of faulty power supply in my fuse panel. Also, I read somewhere threads about leak from the clutch master cylinder can cause damages to fuses. I don't see any leaks but there a lot of faulty electric problems. So whats brand should I get to replace the fuse panel? Get painless fuse kits? Link to comment Share on other sites More sharing options...
cluricaunne Posted January 24, 2011 Share Posted January 24, 2011 the leak is usually in the firewall, so you won't notice it. As for repair, I took the extreme route and completely rebuilt mine, you can see it in my build thread. http://comancheclub.com/forums/viewtopic.php?f=7&t=17707 Link to comment Share on other sites More sharing options...
artimus Posted January 24, 2011 Share Posted January 24, 2011 my clutch master was leaking thru the firewall onto the fuse box. fixed it with no damage to the fuses. :thumbsup: Link to comment Share on other sites More sharing options...
comanche12 Posted January 24, 2011 Author Share Posted January 24, 2011 my clutch master was leaking thru the firewall onto the fuse box. fixed it with no damage to the fuses. :thumbsup: ah thats make sense, i gotta do it asap, what should i replace to fix the leaking? I'm not expert with clutch master cylinder. also I just posted questions in your project about fuses. :thumbsup: Link to comment Share on other sites More sharing options...
artimus Posted January 25, 2011 Share Posted January 25, 2011 my clutch master was leaking thru the firewall onto the fuse box. fixed it with no damage to the fuses. :thumbsup: ah thats make sense, i gotta do it asap, what should i replace to fix the leaking? I'm not expert with clutch master cylinder. also I just posted questions in your project about fuses. :thumbsup: I'm no expert either. check your master cylinder and see if there is fluid in it. if theres not you probably have a leak. what i did when i saw mine was dry is went to napa and got one for $30 and put it in myself, you just need 2 people for each side of the firewall installing new master cyl Link to comment Share on other sites More sharing options...
comanche12 Posted January 25, 2011 Author Share Posted January 25, 2011 my clutch master was leaking thru the firewall onto the fuse box. fixed it with no damage to the fuses. :thumbsup: ah thats make sense, i gotta do it asap, what should i replace to fix the leaking? I'm not expert with clutch master cylinder. also I just posted questions in your project about fuses. :thumbsup: I'm no expert either. check your master cylinder and see if there is fluid in it. if theres not you probably have a leak. what i did when i saw mine was dry is went to napa and got one for $30 and put it in myself, you just need 2 people for each side of the firewall installing new master cyl ah hm I just checked and still full(same amount when i refill after replace the bellhousing few months ago. so it should means that my clutch master cylinder is fine. (I hope) I'll try replace fuse block same time replace the climate control panel that PO trimmed the vents off. :doh: also will try replace clutch master anyway. I just like to make sure everything is ok since I'm picky :roll: Link to comment Share on other sites More sharing options...
