Can someone look up data in an Owner's Manual?
Could someone with an MJ owner's manual look something up for me?
I need to know the GCVWR (Gross Combined Vehicle Weight Rating) for an MJ. It should be in the section on towing (there's a data table there - at least in the XJ manual).
1988 would be ideal but I'm not going to be fussy as I doubt it changed between 1987 and 1992.
Also, what is the best source to purchase a hard copy of this manual? I want to have one for my glove box in case I get pulled over by an overzealous police officer or highway regs officer.
Thanks!
6ft box with classlll, trailer and sway control P205/75R15 GCWR 9060lbs
" " " " " " " " P225/75R15 GCWR 9264lbs
7ft " " " " " " " P205/75R15 GCWR 9264lbs
" " " " " " " " P225/75R15 GCWR 9820lbs
If you want I can copy the chart and send it.
That would be awesome if you could!
I will PM you my email address.
Thanks!
For your own owners manual watch Ebay. I have purchased several for different automobiles from Ebay . Cost can be less than $10.00 if you take your time. Got a full owners manual packet in a factory zipper binder for less than that for my 96 Passat.
From the 1989 owners Manual:
4 x 2
Class III hitch
Trailer weight: 5000 lbs 2268 Kg.
Tongue Weight 750 lbs Equalizing hitch and sway control required over 350 lbs tongue weight.
Engine: 4.0 6 cyl.
Trans: 4 spd auto with trans cooler
Power steering, heavy duty cooling, heavy duty axel all required.
205/75r15 tires with 6 ft box GCWR = 8865lbs/4021kg
as above with 7 ft box GCWR 8969 lbs/4068 kg
P225/75R15 tires with 6 ft box GCWR = N/A
P225/75r15 tires with 7 foot box GCWR = 9645lbs/4375 kg
The 89 manual only list 4x4 with 205/75r15 tires
6 ft box GCWR = 9060 lbs/4110 kg.
7 ft box GCWR = 9264 lbs/4156kg.
My 1991 manual lists the same numbers.
He asked for information from a 1988 owners manual. The information I sent was taken from a 1988 owners manual.
Interesting that the 88 lists GCVW max at 9820 and the 89 is listed at 9645.
Did anything change from 87/88 to 89-92? Could it be the way AMC rated the truck was different from the way Chrysler rated the truck?
