Old man with MJ Posted January 15, 2011 Posted January 15, 2011 Do they ever need replacing.It supplies vacuum doesn't it? My heat switches leak and the axle disco doesn't work,maybe it would run better also?Are they available from Mopar or dealer? Thanks Joe
HOrnbrod Posted January 15, 2011 Posted January 15, 2011 Do they ever need replacing.It supplies vacuum doesn't it? My heat switches leak and the axle disco doesn't work,maybe it would run better also?Are they available from Mopar or dealer? Thanks Joe The charcoal canister's only purpose in life is to receive gas fumes via the fuel return line and reintroduce them back into the intake system for recycling. It doesn't supply or hold vacuum. It sounds like you have a vacuum leak. Most common place for the leak is where the vacuum hose passes through the right front bulkhead and connects to the vacuum canister behind the right front bumper. The hose usually breaks in this area.
Old man with MJ Posted January 15, 2011 Author Posted January 15, 2011 Thanks; I will look into that when the snow melts off!
