88 Dana 35 in place of my 91 Dana 35? Brakes swap?
No, C-clip and Non C-clip brakes (9 x 2.25 vs 10 x 1.75) are not interchangeable. Not even the backing plates will swap. Sorry, but you're SOL on that one. However, if you got ahold of an 8.25, those used the same brakes as the 9" D35.
All XJ/MJ axles used the same U-joint.
