wing window
If you have a Haynes or Chilton manual, there is a step by step process, But basically it remove door panel, drill out rivets holding glass track, 2 screws in leading edge of door, drop down, tilt in, and lift out, then the frame can be taken apart to change out the glass (fixed glass) wing units, need to replace the intire glass track unitl Good luck.
Yeah, no drilling. There's one or two screws on the top of the door, and I think a torx bolt or something inside the door panel. Its a little tricky getting it tilted right to pull out, and even trickier getting the angle to get a new one back in, but it eventually works. I think I have pics of this.
