87 2.5l Accessories SE, WI
xtrm4xjp
I've got most if not all of the accessories from a 2.5 that was pulled from an 87 or 88 MJ. The alternator looks to be pretty new, P/S pump still has the resevior attached, A/C compressor and all the brackets (it does create pressure and the clutch does lock in), plus what ever other brackets came off. I also have the intake/exhaust manifolds with TBI unit attached. Not sure what this stuff is really worth if anythings but let's say $50 for all the accessories and $50 for the manifolds. It was all in a running vehicle when it was pulled and to the best of my knowledge everything should work. Non of this stuff is of any use to me with my 94 YJ so I figured I would post it here for you guys/gals. Everything is located in Kenosha, WI. I can ship stuff for you but it's going to be on your dime. Probably best to email me at xtrm4xjp@aol.com. Thanks everyone.
  • 3 weeks later...
  • 4 weeks later...
Archived
