Ultimate OEM spring rates and codes chart
Pieced from about 30 different sources....
"Chrysler makes a variety of springs for the GC (and XJ, and TJ). There are two main types, base and HD, and in each type category there are 5-10 different springs with different GVWR (Gross Vehicle Weight Rating) capabilities. The springs are denoted by a two digit code as well as a part number."
vehicle build code SDA = normal duty
vehicle build code SDB = heavy duty
V and U spring codes are for right side (passenger), G and F are for left side (driver)
There is a lot of missing info here, so please feel free to let me know if you find the missing info, and I will include it in the chart.
Image version
text version, spaces not lined up.
Model Code P/N Spring Rate Suspension Trim Engine
XJ UD,FD FD 52001113 #570 SDA
XJ UE,FE FE 52001114 #607 SDA
XJ UF,FF FF 52001115 #646 SDA
XJ UG,FG FG 52001116 #688 SDA
XJ UH,FH FH 52001117 #733 SDA
XJ UJ,FJ FJ 52001118 #780 SDA
XJ UK,FK FK 52001119 #831 SDA
XJ VD,GD GD 52001120 #578 SDB
XJ VE,GE GE 52001121 #670 SDB
XJ VF,GF GF 52001122 #622 SDB
XJ VG,GG GG 52001123 #720 SDB
XJ VH,GH GH 52001124 #775 SDB
XJ VJ,GJ GJ 52001125 #834 SDB
XJ VK,GK GK 52001793 SDB W/ UC 4.0
XJ VL,GL GL 52001794 SDB
ZJ UJ,FJ FJ 52088102 SDA
ZJ UK,FK FK 52088103 SDA
ZJ VK,GK GK 52088104 SDB
ZJ VL,GL GL 52088105 SDB W/ UC 4.0
ZJ UL,FL FL 52088181 SDA 4.0
ZJ UN,FN FN 52088362 SDA 5.2
ZJ VN,GN GN 52088363 SDB W/ UC 5.2
ZJ VP,GP GP 52089141 SDB W/ UC
ZJ UM,FM FM 52088361 SDA
ZJ SL,DL DL 52089171 SDA
WJ KF,YF 52088263
WJ KE,YE 52088262
WJ LG,ZG 52089421
WJ KG,YG 52088264
WJ KH,YH 52088265
WJ LE,ZE 52088267
WJ LF,ZF 52088268
WJ K1,Y1 52088269
TJ BD,PD 52088126AB SE 2.5
TJ BE,PE 52088127AB SE 2.5
TJ BF,PF 52088128AB SE 2.5
TJ BG,PG 52088129AB X/Sport/Sahara 4.0
TJ BH,PH 52060130AA Rubicon 4.0
TJ BJ,PJ 52060131AA Rubicon 4.0
JK DA,SA 52126310AB
JK DB,SB 52126311AB
JK DC,SC 52126312AB
JK DD,SD 52126313AB
JK DF,SF 52126315AB
JK DE,SE 52126314AB
JK DH,SH 52126317AB
JK DG,SG 52126316AB
JK DK,SK 52126319AB
JK DJ,SJ 52126318AB
JK EC,TC 52126512AB
JK EB,TB 52126511AB
JK ED,TD 52126513AB
JK EE,TE 52126514AB
JK EF,TF 52126515AB
JK EG,TG 52126516AB
JK EH,TH 52126517AB
JK EJ,TJ 52126518AB
JK CL,RL 68026309AB
