Blower motor only has high speed
I put in new resistor,old one was replaced 5 years ago and still looks new, I plugged another blower motor into plug under hood and still have only high speed. Is there another fuse I am missing besides the one under the dash that would control the other speeds?
Had a similar problem with an XJ. The contacts inside the actual switch had melted. IIRC high was the default,,,,it may depend on how its melted though. I just replaced the entire Temp/Fan Control switch module from a JY XJ. Then it happened again, the actual culprit was the connector. It had melted and ruined the switch. I borrowed the pic from another site,,,,Check this connector and its female counterpart:
