Location of blower motor resistor?
1. Disconnect and isolate the battery negative cable.
2. Remove the kick cover from the heater-A/C housing.
3. Pull out the lock on the blower motor resistor wire harness connector to unlock the connector latch.
4. Depress the latch on the blower motor resistor wire harness connector and unplug the connector from the resistor.
5. Remove the two screws that secure the resistor to the heater-A/C housing.
6. Remove the resistor from the heater-A/C housing.
7. Reverse the removal procedures to install.
