87Chief Posted December 2, 2010 Share Posted December 2, 2010 What will I need for a guage cluster swap? Oil pressure sensor...etc. And what do I get the parts from like in the store what vehicle do I tell them? My Comanche or Cherokee?? Link to comment Share on other sites More sharing options...
pamike Posted December 2, 2010 Share Posted December 2, 2010 this should help. i just swaped mine. if you have just the warning lights you will just need to get the sensors for a cluster with gauges. sensors for cherokee or comanche should be the same. i had the cluster with oil, temp, and batt. gauges allready there. i didn't have to change any sensors. it all depends on what you currently have. viewtopic.php?f=2&t=26063 Link to comment Share on other sites More sharing options...
87Chief Posted December 2, 2010 Author Share Posted December 2, 2010 I'm at work and I brought my TJ to work so I can't look right now, but I know it has the big gas guage on the left and then speedometer then a battery and oil, then umm haha I'm not so sure. If someone could post a pic of the 2 different kinds I could tell them and figure out what sensors I need... Link to comment Share on other sites More sharing options...
87Chief Posted December 2, 2010 Author Share Posted December 2, 2010 I believe I have the same one as you Link to comment Share on other sites More sharing options...
pamike Posted December 3, 2010 Share Posted December 3, 2010 I believe I have the same one as you if you have the same one i did with the rest of the gauges allready there then it plugs right in. if your truck is a 87-90 be sure to get one from those years Link to comment Share on other sites More sharing options...
87Chief Posted December 3, 2010 Author Share Posted December 3, 2010 I got everything plugged up speedo works but the rpm doesn't. Link to comment Share on other sites More sharing options...
pamike Posted December 4, 2010 Share Posted December 4, 2010 I got everything plugged up speedo works but the rpm doesn't. my only guess is either the plug/wire in the back of the cluster is loose or whatever reads the rpm signal from the engine is bad :???: . mine just pluged right in and it works great. other than that i don't know Link to comment Share on other sites More sharing options...
87Chief Posted December 6, 2010 Author Share Posted December 6, 2010 Should I try flipping the plug in the back on the opposite side? Like flip it around and see if that does it? Link to comment Share on other sites More sharing options...
pamike Posted December 7, 2010 Share Posted December 7, 2010 Should I try flipping the plug in the back on the opposite side? Like flip it around and see if that does it? i pluged mine back in with the same plugs in the same location. if it's pluged in the wrong way it's not gonna work. Link to comment Share on other sites More sharing options...
87Chief Posted December 7, 2010 Author Share Posted December 7, 2010 Thanks, In class the other day my instructor said if the speedo cable is loose or not in all the way your speedometer could go back and forth rapidly... Mine does that... Should I pull it out, spray with some brake cleaner then dip some trans fluid on it and put it back in? But would that cause the rpm gauge not to work?? Link to comment Share on other sites More sharing options...
