Headlights dim when I tap brakes ?????
A common thing that leads to electrical bugs in these is grounding issues.Tracing and cleaning the ground contacts usually helps.
I assume it is not a charging system issue as you do not mention it happening when other draws are made on the system, just the brake lights.
