Derek Posted November 22, 2006 Posted November 22, 2006 ok my gauges are done for only one that work right is the voltmeter so i got some gauges to hook up for now till i can build a custom dash panel to house all of them where is the sender for the temp gauge so i can hook up my aftermarket one?
87manche Posted November 22, 2006 Posted November 22, 2006 temp guage sender is in the back of the head, drivers side. I think it's 3/8 npt threaded.
Derek Posted November 22, 2006 Author Posted November 22, 2006 on the back, like up against the firewall? or on on the drivers side but towards the firewall? cause i looked around quick the other night and didnt see anything
Red Dog Posted November 22, 2006 Posted November 22, 2006 The sensor 87manache is refering to is located on the top of the head, driver side, as close to the firewall as the head goes. Its pretty small, 1/8" NPT (if I remember correctly) and is a blind hole drilled and tapped in the head. If you are looking to hook up a mechanical temp gauge (copper capiliary tube) this is not the place to do so.
87manche Posted November 22, 2006 Posted November 22, 2006 you could also go and find an ho thermostat housing, they had a temp sender hole in them.
CWLONGSHOT Posted November 22, 2006 Posted November 22, 2006 NOT THIS ONE!! THIS IS THE ONE YOU WANT!! On the 4.0 Jeep 6 cly. CW
