No Spark
Have a 1988 comanche was running before motor swap. (new) 4.0/AX15/NP231 put in. Pulled powertrain running out of a 1989 comanche, So here's my problem: I have no spark. Have power to the coil (yellow wire) And I have ground. I was reading that I need coil pulse to make it work. Is this correct? And if so where does the coil pulse come from?
Also new crank sensor
New cap and rotor
New plugs & wires.
On a completly unrelated note, I cannot turn my motor over with my key. Turn to run position and fuel pump primes everything turns on, but when I turn to start nothing happens, Are these 2 problems related?
Thanks
Justin
