95 H.O. 4.0 conversion wiring kit SE WI
JeepcoMJ
'95 H.O. aw4 wiring harness, with crossover wiring for "bolt-in" to an MJ completed.
this is the engine and dash wiring, all associated sensors and electronics including:
ECU
TCU
throttle body sensors
MAP sensor
air sensor
distributor
CPS
you also get
full gauge cluster
'95 steering column
cruise control servo (column equipped with cruise)
heater box and controls (newer heater core)
wiper motor etc.
reservoirs
flex plate
$200 for all. this is everything for the conversion except for the engine and transmission itself. local pickup in Franksville, WI....I could probably toss the trans in with it, too.
-Pat
Archived
