JeepcoMJ Posted October 18, 2010 Posted October 18, 2010 96 4 cylinder engine and trans from a cherokee xj. Complete with the wiring, all sensors, and pedal assembly plus ecu, gauges, etc. upgrade your throttle body 4 cylinder to a multiport 4 cylinder, and OBDII as well! The motor has no issues. The jeep was a friend's and he bought it for the 4.10 axles. 120k on it. I've driven it from burlington, a half hour to wind lake (with no windshield, floors, exhaust, or bolted in seat) with not one problem. The trans is an ax5 5 speed, and the master and slave are still there. I probably still have the spare clutch from another one. Good to convert a renix 4 cylinder to mpfi systems, or to just replace a bad motor or trans in any yj tj mj or xj. $400 obo, and I'm willing to seperate. local pickup only, located in Franksville (Wind Lake) WI -pat.
Archived
