Name that problem
So I drove my truck yesterday and it ran fine. Went out this morning to start it and it wouldnt start. Just turned over and over and over but would not fire up. Checked and I was getting spark, checked and sounded like the fuel pump was coming on, but it just wouldnt fire up. So I poured a little bit of gas down the intake and I expected it to fire up and then die but instead it fired up and just kept running. I let it run for about 10 minutes and then took it for a drive around the block....ran fine. So I got home and turned the truck off and re-started it about 5 times and it started fine every time. Then I waited about 4 hourse went back outside and it fired up just fine three more time. What the hell do you guys think was up? Why wouldnt this thing start the first time and why the hell would it keep starting and acting fine once I poured some gas down the intake? The only thing I can think is maybe the fuel pump is on its way out?
