JDub Posted October 8, 2010 Share Posted October 8, 2010 I'm needing a header panel and grill for my '88 MJ. I've found a the parts I am needing at a local JY but they are off of a '96 XJ. Will those parts fit my '88 or will there be mods that have to be done? I would rather be stock as possible. Thanks. J.W. Link to comment Share on other sites More sharing options...
JDub Posted October 9, 2010 Author Share Posted October 9, 2010 :help: Anybody know? Link to comment Share on other sites More sharing options...
Geonovast Posted October 9, 2010 Share Posted October 9, 2010 Yup. You'll need to use all the 96 bezels in order to use the grill, but everything will go right on. Link to comment Share on other sites More sharing options...
JDub Posted October 9, 2010 Author Share Posted October 9, 2010 Ok. Thanks! I have been doing some looking on the internet and there doesn't appear to be much difference in the looks of the '96 grill setup compared to the '88 grill. Am I wrong? Link to comment Share on other sites More sharing options...
nitroxsteve Posted October 9, 2010 Share Posted October 9, 2010 The grill looks the same but the newer grill has the trim that goes above and below the grill opening made to it instead of attached to the header panel. If you use the newer grill you will also need to use the newer head light surrounds. I personaly like the newer set up better it has alot fewer parts. Also the jeep on the top of the headerpanel is glued on instead of the nuts that hold the older one on and the letters are shaped a little different. Link to comment Share on other sites More sharing options...
JDub Posted October 10, 2010 Author Share Posted October 10, 2010 Awesome! I'll be going after it on Monday. The Guy at the JY said the Header panel still has the grill, lights, and Bezels. so I think that will work out perfect. I can't wait to get my truck back on the road. :cheers: Link to comment Share on other sites More sharing options...
