Incommando Posted October 8, 2010 Posted October 8, 2010 My search skills must be way weak. I am looking for some good sources for spring perches and shock mounts to do a SOA on my rear D44 with a minimum of fuss. If you use SOA or perches in a search, for example, the info overload is massive. Anyone have some favorite links saved that they could direct me to? Good photos? Thanks in advance.
mvusse Posted October 8, 2010 Posted October 8, 2010 http://www.ruffstuffspecialties.com/catalog/index.php
jimmy21669 Posted October 8, 2010 Posted October 8, 2010 http://www.ruffstuffspecialties.com/catalog/index.php ^^x2
Motion Offroad Posted October 8, 2010 Posted October 8, 2010 Whatever you go with just remember to go with as long as a perch as possible to help with axle wrap. Also remember that the perch itself in a SOA application can vary the amount of actual lift you get depending on where the "notch" is cut and how much material is above the said "notch".
