88MJay Posted November 18, 2006 Author Share Posted November 18, 2006 I've got the actual cage build pdf. file from S&W for the Cherokee cage. If I knew how to post it I would. It shows the rear bars shaped like this.... ____________ | | | | I assume it's designed to go over the backseat area and attach around the wheel houses in the rear. When I spoke with the salesman he said he could make some changes to the kit if necessary to fit the Comanche. My plan is to order the kit with everything except the bent rear bars. I will ask them to send the rear bars straight not bent. Hope this helps explain a few things. The fellow seemed very helpful. Give them a call if you are wanting to do something similar. I'm sure they will accomadate your needs. :cheers: Link to comment Share on other sites More sharing options...
