Carl'sMJ Posted September 27, 2010 Share Posted September 27, 2010 Here's a question for you guys with some POR-15 experience... Well, I've got my floors torn out of the cab now, but before I weld in the new pans I wanted to POR-15 the inside of the frame rails. There was a fair amount of rust on the inside of the frame and I spent some time today knocking/wire brushing the loose rust off... How carried away should I get with prepping the surface before painting the POR on? I've got the Marine Clean and Metal Prep from POR too. I've been looking at the instructions from POR-15 and it seems that in order to get good adhesion it is actually preferable to paint the POR-15 on rust rather than smooth metal and I kind of figured that just knocking the loose stuff off should be good enough... I was just curious how much prep you guys did before painting and what the results were. Also, Did anyone topcoat the POR inside the frame rails? I didn't see any reason too, but I was just curious. Link to comment Share on other sites More sharing options...
88pioneer Posted September 27, 2010 Share Posted September 27, 2010 Just did my floors on wednesday. Only had minimal surface rust, but painted right over it. The parts that still had factory paint i scuffed up. Should be good to go just knocking the loose stuff off :cheers: Link to comment Share on other sites More sharing options...
1987Comanche Posted September 27, 2010 Share Posted September 27, 2010 I did my floors about a year ago and the only prep was to break off the loose rust and make sure everything was clean and dry. The only problem I had was a bit of peeling where the POR 15 pooled (the same channels where the water pools) but 95% of it was fine. What I've learned with POR-15 is the thinner the coat the better. Link to comment Share on other sites More sharing options...
