help! ba 10/5 trans bellhousing
:fs1: :headpop:
its been anwhile to be that piss on my mj. i almost never pissed at my mj until one simple bolt on top of bellhousing won't come loose and its very cramp space. its ba 10/5 transmission
i took all parts off and bolts off expect there ONE left on passenger top side. :(
so how did you guy get it off? i tried both way from bottom and top of engine to reach it.
easiest way to get it out is put a jack under the transfer/tranny mount,loosen the bolts and let it down a little,from there you should be able to get a 3/8 ratchet with a socket on it prolly a short extension too.it your a 2x4 just put the tranny jack on the tranny and remove the tranny mount and let it down some.don't forget to support the back of the engine when you pull the tranny out.
ahh thanks guys! finally got it out few hours ago. sorry for no reply after read those. i was focus on it all the way...
werid thing is that its easy to install back on than remove :nuts:
once again thanks guys for advice!
You put those ^$%*ing pieces of total @^$ *&$@ing ($ back in??
