changing location temp sending unit
some of you know that I did the 4.0L swap in my 86 comanche
now I just received my thermostat housing with the temp unit hole so I wanna relocate it from the back of the block
to eventualy run an electrical fan setup
Q's : can I reuse the same temp unit form the block ?
if so what do I use to plug that hole? ( just a cut bolt?)
if not Ive read that after market sending unit are not the best ........ go with a mopar one?
comment and input plz!!!!!
Use the same sending unit. If you get a after market unit you may have to get a matching sending unit. Read the instructions.
A bolt would work but a brass plug would be better.
Stewart Warner makes the best after market gauges in the country. Don't get that chintzy dime store stuff.
