Hooked Posted September 16, 2010 Share Posted September 16, 2010 I,m going to build a new frame to set my MJ cab and fenders . want to keep the same WB. Plan to use 3 x 6 x 10 ga. tubing.Can any one tell me if I'm going in the right direction? Link to comment Share on other sites More sharing options...
mvusse Posted September 16, 2010 Share Posted September 16, 2010 Do you realize the cab is unibody? As in the frame is part of the cab and they are not two separate pieces bolted together? Link to comment Share on other sites More sharing options...
