MjPioneer Posted September 8, 2010 Share Posted September 8, 2010 I have already locked my cad system, I have happily run that system for years with no complaints. Next spring I plan on rebuilding my d30, I was looking into a "Upgraded axle shaft kit" but this system is not for a cad axle. Can I install these axle shafts in my cad axle? In theory it sounds like it will work just fine to me, but I want to double check with you guys before I buy something I don't need. Link to comment Share on other sites More sharing options...
TrailReadyMJ Posted September 8, 2010 Share Posted September 8, 2010 The shafts will work fine, however there is a major difference in the seals. The CAD axle seals at the disconnect housing, where the one piece seals at the diff (like the driver side). However they do make a kit just for this. For example http://www.emsoffroad.com/store/index.php?main_page=index&cPath=65_68 Or you can swap in a non-disco D30 from a newer Jeep, or any XJ with the 242 T-case. Some like the disco housing for the stronger UCA mount, but this is what I did and I haven't had any issues with it. I also plan to 3 link it as some point, so it will probably not be used anyway. Also, the newer D30s came with the larger U-joints in the shafts, so an upgrade isn't as necessary. I have broken a couple of the small joint shafts, but actually stripped my ring gear with the larger ones! (see build thread for the story, link in sig) Link to comment Share on other sites More sharing options...
