fogtlight question
really? i didnt realize my rollbar have hole ready to put wire in it haha
will it go all thru way to bottom to underbody?
thank you! :cheers:
there is holes in the front lower part of the bed to run the wires through they are in the bed bulkhead at the bottom in the corners of the bed
I would look at routing the wires between the cab and the bed. Our trucks at work route the wires from the Back Rack between the cab and bed through a hole drilled in the back of the cab and sealed with a rubber grommet and then along the drivers side of the truck under the trim and kick panel then up to the fire wall.
Those holes at the bottom of the bed bulk head are for drainage.
I just don't like the idea of wires running inside my truck bed where they are prone to damge from the cargo I am hauling.
