In side lights dont work
All the contacts in the light assy itself need cleaned of built up corrosion. I had to do this on mine too. you even need to clean the little wheel in the light as it is metal too, though it may not look like it. This is all assuming you have power getting to the lights in the first place. Get a test light to check the wires at the lights... should be one hot all the time, one hot with the doors open but dead with doors closed or hot with headlight switch turned to dome light position, and the third will be a ground. Remember too that the lights themselves toggle to different positions, to be on all the time like a map light, or only on with the doors open or switch turned on. Good luck.
