High idle
My mj revs high when in park any thoughts? My dad says it may be the idle control some thing rather lol that may be a help. thanks
Was it warm out?
If the IAC gets warm, it can cause the vehicle to idle high. Out here in the desert it happens quite often.
We went wheeling with 4 XJs/MJs and 3 out of the 4 vehicles were doing the same thing you are experiencing and it was about 105F out.
You may try swapping out the IAC with another one and see if it solves your issue.
Was it warm out?
Its Florida what do u thank? lol if the heat is what makes this happen would replacing the IAC fix the high idle or should i just leave it be?
