cluricaunne Posted August 13, 2010 Posted August 13, 2010 Just pulled my dash out to get the harness out, it was a pain in the @$$, anyway, wondering, while the windshield is in, what is the easiest way to get the vent panel out to remove the bolts that hold the dash in on top??
XJGPER Posted August 13, 2010 Posted August 13, 2010 I pulled the dash in my '89 to put AC in, i used a 1/4" socket driver (the screwdriver handle with the square 1/4 socket driver) with a wobble and a #2 bit wrapped in electrical tape pressed into a 1/4" socket. I was then able to sneak the bit in and make the corner with the wobble before it makes the windshield. #2 Bit -> 1/4" 12 pt socket -> wobble -> 1/4" drive handle. Its not hard takes a bit of patience, but so does converting a MJ to factory air...
cluricaunne Posted August 14, 2010 Author Posted August 14, 2010 damn, I was hoping that wasn't the answer, that's how I did the first one, except I have a 1/4 socket designed for bits, so I didn't have to use the electrical tape
