Jerry Posted August 5, 2010 Share Posted August 5, 2010 While I'm messing about trying cure my ailing cooling system is it OK to use plain water instead of the green stuff? I'll probably need to drain it down a few times before I've cured all the problems so I'd like to use water so I can just dump it on the ground. In the haynes manual it says not to use plain Jane water in a pressurized system because it'll boil where the green stuff won't :hmm: Link to comment Share on other sites More sharing options...
Eagle Posted August 5, 2010 Share Posted August 5, 2010 The boiling point of water at sea level is 212 degrees F. That's about where the Jeep engines run. The boiling point for 50/50 glycol mix is up around 250 or 260 degrees. Plus, plain water in the engine will start things rusting inside your block before you can blink. Save your coolant when you drain it, strain it through cheesecloth, and re-use it. Link to comment Share on other sites More sharing options...
Jerry Posted August 5, 2010 Author Share Posted August 5, 2010 Thank for the advice, I'll use coolant :thumbsup: Link to comment Share on other sites More sharing options...
