comanchedude Posted August 5, 2010 Share Posted August 5, 2010 Hello Need a good fuel tank sending unit for my MJ. needs to be in good shape..mine has rusted tubes.. Link to comment Share on other sites More sharing options...
shark Posted August 5, 2010 Share Posted August 5, 2010 Me too! Link to comment Share on other sites More sharing options...
deziped Posted August 11, 2010 Share Posted August 11, 2010 Would that be for an 86? Link to comment Share on other sites More sharing options...
92tanMJ Posted March 22, 2013 Share Posted March 22, 2013 Mine has a brand new pump and tank in it, if I do the 98+ swap. Those parts will be up for sale Link to comment Share on other sites More sharing options...
Tom Tom Posted March 25, 2013 Share Posted March 25, 2013 I have a swb tank with a sending unit Link to comment Share on other sites More sharing options...
1ton87 Posted March 26, 2013 Share Posted March 26, 2013 i am in need, my sending unit just started leaking last friday. what is the swb tank? Link to comment Share on other sites More sharing options...
Tom Tom Posted April 3, 2013 Share Posted April 3, 2013 swb (short wheel base) it is a shortbed tank Link to comment Share on other sites More sharing options...
1ton87 Posted April 3, 2013 Share Posted April 3, 2013 guess mine is a lwb then. no worries, i got her fixed up. found a NOS '86 mj sending unit off of eBay, & had it sent. took a little cutting and splicing with the old unit, and had to switch out the wire harness. (apparently the '86 had an engine driven fuel pump?) but i finally got it together so that i have new send & return tubes coming off the side of my tank. installed it and turned the key - nothing. took me a while to realize that i had isolated the pump with a peice of rubber hose. pulled it out & installed a ground (duh!!!) between the lower & upper halves, back into the truck, and the pump & gauge work just fine again. no leaks, just as i like it! would have been alot easier if they still sold the '87 sending unit somewhere, but oh well Link to comment Share on other sites More sharing options...
