manimal Posted August 1, 2010 Posted August 1, 2010 I have read MANY threads on the rear load sensing valve. I am unclear as to which line I can leave/use,and which to remove to eliminate the valve. I am installing an XJ prop valve in place of the distribution block, and want to get rid of the NON functioning load sensing valve. My brake lines are in GREAT shape so I don't feel I need to run a NEW line. Thanks
CWLONGSHOT Posted August 1, 2010 Posted August 1, 2010 The search isn't perfect, but it does work. :brows: search.php?keywords=load+sensing+valve&terms=all&author=eagle&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search CW
manimal Posted August 1, 2010 Author Posted August 1, 2010 THANK YOU! Got it all taken out and the XJ prop valve back in. Thanks again
